full hydro HELP
tjsjr
Registered Member
Holts Summit mo
:confused:i got my steering all hooked up today and when i started it up to finish bleeding it the steering wheel started spinning violently on its own and i didnt dare to grab it. i shut the truck off and held the wheel while just turning the motor over and i couldnt hold it. i am using a tractor orbital valve and a TSC 2x8 single ended ram. i have the presure hose from my pump going to the IN port and the OUT port goes to the return. the L port goes to the side of the ram that pushes left and R to the right. WTF
Double check all of your connections. Also, do you know for sure that your orbital was good beforehand?
so the valve was bad??my buddy had one off a forklift and the first time he started his it spun all the way to the left and he couldnt turn it back he had to get a new valve
thanks good to see threads like this because full hydro is such a unknown its good to learn anything..any pics of your setup
