Full time 205 question
puckhead
colorado
can a full time 205 be made into a part time and would it be worth it to slave on my back in a dirt yard to get a 465/205 combo for 80.00
a 205 is a part time case. its the 203 case that is fulltime, and it can also be converted(via the best method) for about 300 bucks.
id dig that 465 and 205 out even if you dont need it. you can prob sell it easily for a couple hundred bucks.
whats your current setup?
so all 205's are part time then?
if i pull it im going to use it u can bet that i also spied a 203 sittin in the back of another just waiting to loose its range box
if i pull it im going to use it u can bet that i also spied a 205 sittin in the back of another just waiting to loose its range box
All 205's are part time. It is the 203 that you use the range box from to make a doubler.
