SUB602 said:Can someone tell me what it takes to remove fulltime hubs from my 75 K-5? Thanks in advance.
SUB602 said:I guess i didnt bang hard enough. I started to remove those covers than thought you know i better find out if thats the way to go so i dont end up doing more damage. Cool!! Thanks for the info.
sweetk30 said:dont forget if you still have a 203 full time tcase with out conversion kit installed you will need to keep the hubs locked in or it wont drive.![]()
I wouldn't worry about the wheel studs, you'll break your axle shafts long before those give out.![]()
Seriously? So this would be a good way to tell if you have the 2WD conversion done?
Sweet then I guess my 75 already has it done! I have been driving it around with out the hubs locked for a while. So, it would not move at all with the hubs unlocked? Unless it was in high or low lock though?![]()
