Im currently building a cage and some may say you can weld the underside of a joint but I dont buy into it. Ive been welding for years and never had a decent weld while trying to weld from the bottom. Ive heard tons of different ways to make it work, it just does not happen with me ive tried.
That being said I made the entire cage removable but before pulling it off and welding it I have concerns. I buy into the theory that it will warp or shrink if fully welded off the vehicle. This vehicle has no roof or sides so welding the top and sides is not a issue. I was thinking of welding the bottoms, then putting the cage back in and finishing it off. I was thinking that may lead to less shrink/ warpage.
The other thought is to weld all the joints I can get to then pull the cage out and weld it. Seems like a bad idea going this route though. Whats the best way to go about this?
