Most of the time The Blazer is water tight. Light rain and even the car wash it doesn't get you wet. Big Ugly...not so much. The Blazer's vent windows even seal up still!
However I'm discovering some leaks now. There's surface rust on both of the B-pillars behind the doors below where the top ends at the front. Top seal maybe? It's looking rather porous on the outside. Looks like the top has never been off but there's definitely been enough water in that area over time to make the carpeted pieces on the sides down near the floor get funky/moldy on the back and the surface rust to appear around the seams. Meanwhile as I'm looking at the interior trim pieces I'm thinking they look a bit warped too.
I found water on the floorboards on the passenger side in this area last week after a driving rain.
Then in the back...
When I got it the rubber seal that sticks to the tailgate was just hanging down loose. I stuck it back in place but now I'm discovering water gets past the seal on the edges. Meanwhile the side wall trim is also loking a bit warped in the back as well. I'm afraid this is possibly the doing of the previous owner with the radio fetish.
So am I just looking at new seals here or are there other potential problems? Other than some surface rust and general annoying clean up work I haven't seen much else that's scary.
Then in the back...
one day i layed on the seat durring a good rain and watched the water drip of the choke cable abd other things i had run through the whole. ha HA!!
just a suggestion,bro.
