Ok, I lost power on one of my plugs on my fuse block.
From the factory it had a little green plastic clip that went on the green circled pin. I had my tach power and a small switch that ran to an extra horn relay hook up to it.
If you look at the wiring diagram you can see where the connector is on inside of the cab fuse block and where it is on the back side of the fuse block.
My question is how could this lose power when there is no fuse in the circuit? I check the fuse blow it and it's good.
