robert97dodge
I bought a couple Blue sea fuse blocks that I had some questions about wiring. One is a 6 circuit with negative bus and the other is a 12 circuit with negative bus.
Here is a pic of the 12 circuit one. The 6 circuit looks the same but is shorter with only 6 circuits.
The ground wire goes in at the top I have grounded to the frame and the bottom is for the power I have coming from the battery. How I think it works is you use each of the 12 circuits to hook up 12 different products. According to the wiring diagram the left side of the positive section is positive feed and the right side is to device positive. The left side of the negative section is negative feed and the right side is from device negative.
Here is a link to some specs about the blocks. I have part number 5025 and 5026.
http://bluesea.com/products/5026
