fuse box question SOLVED
big83chevy4x4
3/4 ton status
Sheridan, Michigan
are the "ignition" ports on the fuse box fused in some way?
i have the lockup converter, off road lights, and the plow controller all plugged into a different one and none of them work. (the plow controller doesn't work because the plow is not on the truck) there are no fuses blown in the fuse box
ive looked and don't see anything wrong with any wires /forums/images/graemlins/thinking.gif
EDIT: they are fused, on the far left of the fuse box it goes from top down
IGN
IGN
20 amp fuse
IGN
the 20 amp fuse powers the IGN ports, it was blown. i moved the lights to a BATT and put a new fuse in and everything works.
Re: fuse box question
Not quite sure if they are fused on the fusebox, perhaps the fusible links in the engine compartment.
I do know you shouldn't run the lights off the fusebox. You run the lights to a relay under hood attached to battery , and then run a smaller 12 volt switched source for triggering relay, that can be ign of fusebox. /forums/images/graemlins/k5.gif
sounds kinda like a fusable link problem, check the wireing down by the starter, look for burned wireing, sometimes it'll burn the wire and not harm the insulation. good luck! /forums/images/graemlins/whistling.gif
Without looking at my electrical manual (from '86) some are fed (all?) through a 30A circuit breaker that is on the face of the fuse panel. Not a real good idea if your accessories don't all need 30 amps, so thats why I purchased a small 6 terminal aux. fuse panel.
The accessory ports are run off of metal "strips" on the back of the fuse panel...one wire will run to the strip, and that strip is the "feed" for say 3 or 4 of the fuses in a vertical line.
The shunts on the fuse panel connect those strips of metal so that you might have 2 of those metal strips (maybe 4-8 accessories) running from the same power wire.
Only two fusible links IIRC that feed the fuse panel, and if you lose one or the other, either the engine won't start, or the headlights won't work. This is from my knowledge of the same vintage GM cars which use the same fuse panel...you can't lose a fusible link without having one of the problems I mentioned above.
Makes sense I hope.
everything else works fine.
i noticed the problem after i welded the floor in, i bumped the light switch and didn't notice it was on for 30 minutes of driving. a little while later the converter wouldn't lockup. /forums/images/graemlins/dunno.gif
anyone got an electrical diagram for an 83 truck? tazz?
