What causes a fuse to instantly blow when you press a switch? This has to do with my rear window on the K5. All was good until one day, pop. Dash and key are dead. Window works fine using jumper cables and a battery, but using either switch blows the fuse.
I've done a thousand things to the truck since the window last worked. Narrowing down what I did that *&<^#?*@$&*(%# the window is gunna be kinda hard.
