buckallred
Registered Member
- Joined
- Feb 11, 2013
- Posts
- 64
- Reaction score
- 15
Hi:
The fan suddenly stopped working. I figured out that it is because the fuse is popping every time I turn on the heater or AC or defrost etc. It's a 30-amp fuse. 89 burb 2500, 6.2 diesel.
This happened fairly suddenly and for no obvious reason. I've replaced the fuse 2-3 times and they keep popping. It has been wet and rainy here. Everything else seems to be working fine. All lights, dash lights, stereo, interior lights.
Is there any advice, and specifically any hope of an easy fix? It's nearly always a grounding issue, as I understand it. I appreciate all advice and help. Thank you.
