4xcrazy
3/4 ton status
I haven't done a ton of research on these ideas as of yet, been busy with a lot of house stuff at the moment, so bear with me please.
So here's the deal. The '05 half ton Avalanche, equipped with the stock 5.3/4L60e just is not what I feel it should be for the future plans we are seeking for this ride.
We're planning on buying a decent sized travel trailer, guessing mid 20 foot length. I really don't believe that size should be a problem with towing if setup correctly.
The issues I am having are the fact we are planning on doing ALOT of towing with it, like cross country touring with this thing, lots of miles and whatnot.
Concerns?
This engine was just rebuilt two years ago due to a failed lifter roller wheel chewing up the cam. Instead of just a cam & lifter replacement, we opted for a complete rebuild.
Even before the rebuild this engine just never seems "right" always making weird noises and idle issues, difficult to describe really, but tinkering with engines all of my adult life, and with this supposedly newer, better designed engine platform, I really don't feel this thing is running or working properly.
It's never had a piston slap issue before the rebuild, now it does pretty good. I will usually let it idle for a few minutes until it goes away before driving off with it, seems to do fine.
I call this the "Monday engine" to me, it's just not right.
The transmission? well. it too has already been rebuilt. This was caused from an overheat issue from a return trip to Arizona from SoCal area one year. We had the entire bed loaded up with luggage and the 4 of us in the truck, climbing through some of the hills, it was going in and out of converter lock up, overheated it and burnt up some clutches. Eh,, what's another $1500, right?
So I'm already certain that if we want to pull a decent sized trailer behind it, it would be beneficial to have the rear end regeared, which I had really planned on doing anyways due to it's somewhat seemingly low gears set for highway crusing. But I did have some other ideas I'm pondering and that's why I'm posting here, to get your thoughts and ideas.
SORRY !!! this is turning out to be a Fordum post...
(just kidding Fordum)
Here are my thoughts.
This truck will be paid off later this year, we didn't really want another truck payment, so buying a truck that's more capable and easier to tow with is pretty much out of the question.
Since I don't like the engine in this thing as it is, and am getting to the point that I would just like to possibly swap it out for a brand new GM replacement, why not go with a 6.0ltr. I know the fuel mileage would drop some, but from what I have seen by other peoples trucks, they pull much better, with ease.
The transmission still runs and shifts fine and after the first one burnt out, I use that tow haul mode selection a lot more when heavy, pulling anything or just want to make sure it holds a gear a bit longer during an uphill climb.
BUT..
Seeing as it will be pulling a travel trailer, wouldn't it be better to have say a 4L80e or something better for that type of continuous work? or do ya think it'll be fine with it's current trans with a good sized trans fluid cooler installed.
I also realize all of these mods are not exactly cheap, but they are much cheaper than a new ride, and at this point in this trucks life, it's about due for some upgrades and repairs anyways.
The other idea?
The other idea I have been pondering is just to break down, acquire another vehicle payment after this one is paid off, and buy a newer/used C-class style of motor home in the 30-32ft range. But then we'd have the task of trailering the truck around with us behind that, which just seems a bit large.
I personally prefer the idea of a self propelled motorhome, no wear and tear on the Avy at all.
Concerns?
(just kidding Fordum)Here are my thoughts.
BUT..
The other idea?
