twisted boost
Registered Member
For Sale: G.M. 14-bolt 8-lug rear differential! 9.5" ring gear semi-floating ¾ ton with 3.73 ring & pinion gears and factory G80 gov-lock! Perfect for replacing wore out unit, or upgrading ½ ton running gear! Came out of 1985 ¾ ton Suburban, but will fit most al 1973-1987 G.M. ½ & ¾ ton trucks, Blazers, & Suburbans. Will also fit 88-91 full size Blazers, Jimmy's, and Suburbans will let this go for 175.00 or reasonable offer
