Irish Wake
Registered Member
1988 K5 Blazer
Gas guage was stuck way above full. I dropped the tank and the metal cover that covers the end of the float arm had come loose. I reattached it and tested it with a 12V test light. Bright on Empty Dimmer on Full. Put everything back together and now the guage reads 1/2 when tank is empty and a little past full when full.
The guage doesn't bounce and did go to Empty when I grounded the sender wire.
Any suggestions? Thanks
