gas guage dancing
Well it's pretty difficult on a pickup, I imagine it'd be even harder on a blazer. It's easy if you pull the tank, if you're into that sort of thing. I just ran a new wire to my tank, cause the terminal the old one clipped to had broken off, and that whole area was inaccessible. I just ran a tek screw with a ring terminal into the corner of the tank, you know the flat, pressed together part that sticks out all the way around the middle of the tank? Figured if I stayed close to the edge I could run a screw in it without causing a leak. Worked great, for me anyway.
