Be careful how much Lucas oil you use in the engine. That stuff creates drag and causes the oil to return to the crank case slower. On a stock small block turning no more than 4500RPMs, you'd probably be ok. On engines that turn higher RPM's or that have a HV oil pump, it could cause oil starvation and actually overheat the oil and cause it to stop lubricating faster.
You've seen the little displays Lucas puts out that you crank and you can watch the oil "climb" the gears? Look carefully, there is oil all the way to the top of the "regular oil" side, and the sump is full. The Lucas clings and gets very thick at the top and almost empties the sump.
The problem is that the oil in the sump is for cooling. The "regular oil" side has oil all the way to the top, in a film, working like it is designed to and draining back to cool. The Lucas just sits on the gears, creates the little webs between gears (pre-windage and drag) and has very little oil left in the bottom that is allowed to cool.
