72 Blaze
OK guys anyone every install a new gas tank from LMC? It says you have to move the neck to the new tank. Sounds easy enough! But dang you pay 200 bucks! I wonder what that really means? Just the turn of a screw driver? Or cutting? Just thought someone out there has already done this and I wanted to see how bad it was going to be. Or if anyone knows where else to get a direct replacement?
Also: still having trouble at mid throttle. Runs good and will sit and rev up all day. Runs good down the road but after a hard full throttle it starts to flutter a bit and then pick back up when a mid throttle is applied. Fuel filter is new Dizzy is new and the carb is new its a 1406. I'm pulling around 19 vacuum at idle. No spark knock.. Timming seems to be good!!!
It's a 350 crate...
It's a 350 crate...Thanks
