cameronsaddress
Hello,
A couple of things. I found a large hole that seems to have been repaired (poorly) in my gas tank. Is this serious or common? Do I need to plan on replacing the tank soon?
Also, the dimensions of the tank are: 11.5" deep x 15" wide x 27" long
How many gallons do you think it should hold? I have only been brave enough to put in 17 gallons...
Repaired hole:
Do you see any other issues with it that I should be concerned about?
Repaired hole:
