badmix
Im going to drop my tank to clean it up some (paint outside with POR15 and replace the short rubber lines with some Marine Grade E10 resistant lines)
Anyways, my fuel gauge will act funny, always has. If I fill the tank all the way full, itll read past the full mark and it will stay that way for awhile while I drive and then ill hit a bump or park the truck and then all of a sudden itll read correctly. It has been off by 1/4 tank in the past, ive only ran out once. And then on occasion itll read normal, so I just make it a habit to monitor how many miles I drive etc.
Well, since Im dropping the tank, would be be who of me to replace the sending unit or is it best not mess with such things until it totally craps out. I mean my gas gauge works more of the time, but id like it to be 100%, I just dont want to cause more issues by opening up the tank and replacing it. My truck as 144k on the ODO and im sure its the original sending unit. And will the sending unit be compatible with my OEM gauge? Has this ever been an issue?
(the original one was fine even with 175K on it). Sending unit is fine though (they're very simple, hard to make a crappy one).
.7k later i wished i hadn't
