I’ve got one like this I put on my 74. Installed a 31 gallon tank and it does not fit, too shallow.
Curious about the one TJ1978 bought fits the 31 tank.
IIRC the 31tanks came after 74ish.
I have 40 gal tanks fits close to bottom of tank
I had the same one in my 76 k5.I’ve got one like this I put on my 74. Installed a 31 gallon tank and it does not fit, too shallow.
On the side it is too close you can put some spacers to lower the skid a little.
Its close to flush against it on driver side, does it really matter much? But I will try what you suggest
By Flush I mean on the side of the gas tank not the bottom. The bottom is fine. The solution would be if I could shift the gas tank to the passenger side by an 1/4 inch which seems more trouble than its worth...
If it's only touching on the side you are fine.Ill mess with it tomorrow see if I can move it a bit...
@dyeager535
