original balzer
For some reason or another my 77 K20 only came with 1 gas tank on the pass side.
I thought someone might have removed the other one but the bed doesnt have a filler hole I even looked inside to make sure someone didnt patch it. So I looked at the frame and it does not appear the driver side saddle tank was ever installed.
I have a few tanks so putting one in wont be too big a deal.
Thinking about it my 1972 K5 had 3 tanks. the main rear tank and 2 home made side tanks.
I have a K5 tank as well......
So I want to install it too.
My 72 ran on eaiter the main tank OR BOTH aux tanks at the same time.
Is there a way to single out 3 tanks? Im guessing all 3 tanks would need vent and return lines. would the return lines need to be switched as well?
Also was wondering if anyone has ever run 1 filler neck for more than 1 tank? I would think that if a T was used down low and the vent tubes all ran to the 1 filler neck it sould work ok. This way the first tank would fill up then spill over through the T to fill the other tanks. The vent tubes would have to be higher than the T Im sure. It would be crazy to fill up all 3 tanks at once.
Please give your thoughts and sugestions.
OH FWIW I would like to graph a fuel door into the bedside, being a 77, it has the gas cap without a door and its actually a pain to fill due to the angle.
