Gas tanks
pennsylvaniaboy
pennsylvania, 15537
ok guys im gonna be puttin sliders and a cage in my rig here soon and i have dual side saddles. i am thinking about putting a blazer/burb tank in the bed kinda like a fuel cell. but does anyone see an issue with putting a sidesaddle sideways at the front of my bed?
I did on one of my trucks. fit perfectly under the tool box I was using. Make sure it is bolted down good and you have some type of grommet in the hole you run the fuel lines through.
Like John's?
lol thats cool but i got and 8' bed so i can throw a sidesaddle and on lose like and 16x16" by like 4' in the front of my bed and maggot ive been looking for you i gotta meet up before school is out and what kind of tank is that
Huhhh??:D
so you cant run sliders with the saddle tanks?:confused: even if you make custom mounts?
yeh just wont be a supported as i would prefer. its a big truck and i like to build beefy. besides im not using the bed space for hauling. so its no biggie. does anyone see a problem running tanks this way
ive done several post recently about tanks in the bed (aux tanks, and fuel cells in the bed), but decided im just going to add a saddle tank on the left side. guess i might not be running sliders depending on how bad the mount is
yeh they are cake to mount on the sides real easy if you have brackets. i got two brandnew tanks that came with my trruck when i bought it. but i will also be puttig in a cage that goes through the floor and to the frame which is another reason the tanks cant stay sidesaddle
the only ill effects I had was when it wasnt bolted down very good. came loose while I was driving down the road and pinched the gas line.
but personally if I had it to do over again I would add a blazer tank. I think it looks a little cleaner then having that odd shaped saddle tank layin in the bed.
Well, I haven't seen it mentioned yet, but I've been thinking of it lately. Why can't the saddle tanks be run side by side between the bedrails. I just don't know if there's room to do it, I haven't measured or anything. But if it could be done, you'd have the capacity for fuel, room to mount the sliders, and it would be easier to fab a skid plate for the fuel tanks. Say 10ga. sheet from framerail to framerail.
Could someone measure the saddle tanks and between the frame to see if that's possible?
