vandelay industries
GASKET SEALANT ON FUEL PUMP TO MOUNTING PLATE GASKET, YEA OR NAY?
AS A Side note, a)the fuel pump pushrod position on a 4.3 v-6 is different from a v-8; You can't use the long upper bolt trick to hold it in position.
b) While the v-6 and v-8 pumps appear identical, body wise, i don't think they are interchangable because i think the v-6 pumps put out a little less pressure than the eights in a lot of cases, so it's best to make sure. Also the fittings will be in a different position because the v-6 pump mounts upside down and i think higher on the block. i think they did this so it would clear the front crossmember?
