hickmanfab
Registered Member
So I snapped my adapter between the two
so now that they both out I might as well as redo all the gaskets seeing that is leaked like a dirty sponge. Thus the questions:
1) what do you guys use for gaskets between the adapter on tranny/t-case and where did you get it at. Will silicone gasket maker work?
2) The best way to put the beast back in
. Is there a trick to get the coupler spines to match up to the t-case and the tranny?
3) Is there supposed to be some kind of brace that bolts on to the 205? Mine doesn't have one, but there is bolt holes on it.
so now that they both out I might as well as redo all the gaskets seeing that is leaked like a dirty sponge. Thus the questions:1) what do you guys use for gaskets between the adapter on tranny/t-case and where did you get it at. Will silicone gasket maker work?
. Is there a trick to get the coupler spines to match up to the t-case and the tranny?3) Is there supposed to be some kind of brace that bolts on to the 205? Mine doesn't have one, but there is bolt holes on it.
, but that is a whole nother story for a different day.
