habitatxskate
gah my rear seal on my motor leaks, i dont really care bc it barely leaks, but my tailshaft on my np208 tcase leaks and im not sure which gasket i need but it pisses it so i really do need to change it
http://www.partsamerica.com/ProductDetail.aspx?MfrCode=MR2&MfrPartNumber=S9449&PartType=1347&PTSet=A
is this the right one?
between my trans and trans mount it leaks but not much so i'm not going to take that all apart..
and one more thing, on my front driveshaft where it bolts onto the tcase it leaks, how does that happen? there is nothing above it and i'm next to positive there is no fluid running through it...
and one more leak, the seal where the driveshaft connects to my rear (14 bolt s.f. from a k20) it leaks a little, is that a pain to change? i mean i have to take my driveshaft off anyways so if i do it i want to do it now, would that be worth it?
and for my starter you may have read about i'm just going to order a rebuild kit for like 16 bucks which has the shims and everything else, that is simple im pretty sure so thats about it, can anyone tell me if im in the ball park?
oh and transmission thermometers i read they are really worth it, so how hard is it to install and how is it done exactly?
