gauge cluster loss of power
mostwanted
Kansas City, MO
I was driving down the road the other night when I noticed a spark under the dash then all of me gauges stopped working (except speedo). I check all of the fuses and all are good. I checked for loose connections and found none. Which harness does power come from and which pin if anyone kknows? Any other ideas are welcome.
If you saw sparks then more than likely you have a bare wire, probably from rubbing against something or from someone splicing wires and not correctly covering the splice. It should be obvious once you contort yourself and look under the dash.
You probably did this already, but I find that it's a lot easier top remove the dash pad (9 screws - 4 at the top of the instrument bezel, 4 above the glove compartment, 1 on the right side that you can see when you open the passenger door, the pad slides back and comes right off, easy as pie).
Clean up any dust while you have the dash pad off, if your instruments look dusty, pull the clear gauge cover and vac the dust off of the gauge faces.
(I pull the dash pad just to change bulbs, instead of crawling under the dash. It takes a couple of more minutes, but it's less neck acrobatics.)
