Any problems with hacking the gauge cluster to fit the 2 1/16" autometers on the side and leaving the print circuit loose behind the dash
so the fuel and speedo still work and are lit up? Could I use existing wiring for the lights to light up the autometers?
I will have a volt/ elec trans temp / mech oil psi / mech h2o temp
also an air pressure for oba but that will be to the side, near the vent
Promise to post pictures
and thanks for any help, just trying to get a feel for the install before I get started
also, I found the best method for making the holes was a 2" hole saw and a keen eye/steady hand
so the fuel and speedo still work and are lit up? Could I use existing wiring for the lights to light up the autometers?I will have a volt/ elec trans temp / mech oil psi / mech h2o temp
and thanks for any help, just trying to get a feel for the install before I get startedalso, I found the best method for making the holes was a 2" hole saw and a keen eye/steady hand
