- Joined
- Mar 3, 2000
- Posts
- 9,123
- Reaction score
- 7,077
I have a 14 bolt FF 10.5 ring gear with 4.10's I am comparing cost and benefit of gear change vs doubler, 4 to 1 etc. Front is a 3/4 ton 10bolt with upgraded shafts and its welded.
The rear has a detroit locker. If I change gears can I just order the ring and pinion and have it reset? Can I use the locker I have or do I need a different one with the new gears?
What determines whether you need a new carrier (like I know what that is).
thanks
thanks
Talk about spending the most money you possibly can!!!
Oh and find another money tree.
