ive gotta put in a new tranny in the K5 so i figure while its undriveable i might as well build the 14 bolt. hopefully saturday night but probably going to be starting on sunday, needs to be finished by sunday.
im a little unprepared, as you can tell.
first off, the most important is to install the detroit. i havent run it but supposedly the gears are setup stock from GM.
so basically the order of operations is:
punch dots on the big nuts with holes in them and the bearing caps?
then unscrew them two turns on both or just one side?
then i can pull the carrier just like that?
do i need to mark the ring gear position on the carrier, or does it not matter?
i have to remove the ring gear bolts, do i need new ones?
make sure i remove all of the washers, six total if i remember right.
for the detroits outside most gears, do the smooth parts or the teeth go towards the inside?
for the long bolt to install, how long do i need to get? its pretty damn hard to compress.
im assuming installation is the reverse of removal.
where can i get some of that yellow gear paste?
then for the brake lines for the discs, is it chevelle soft lines? ill be using 84 calipers that i have. i could always get the older style if needed.
regular ol wheel studs will do the trick?
for the fitting from the T above the diff, what is the thread pitch?
then the fittings from the hard to soft lines? and then caliper threads?
i have the "big" ten bolt with 1350 yoke, i reccon i can use those same straps off that yoke?
i seriously apologize but i dont really have the time to be doing all that reading. gotta go wrench!! thank yall BIGTIME
im a little unprepared, as you can tell. first off, the most important is to install the detroit. i havent run it but supposedly the gears are setup stock from GM.
