Irish1941
Not very tech but ever have the gear indicator get stuck?
Every damn truck I ever had gets stuck and then the little cable breaks. One of those small fixes that always bugs me until I get bugged enough to just fix it.
Happened the other day to the '89 so I fixed it for good.
Seems the cable was getting caught up on the plastic guide and chewing up the cable.
I pulled off the dash bezel, pulled off the tiny cable and took the smallest heat shrink tube I had and slipped it over the cable, shrunk it good and tight then put it back on. Used a little spray lube on the outside of shrink tube. Then lubed up the indicator slide as well.
Done. Slides back and forth with no hang ups and took maybe 10 minutes.
