Gear lube weight?
mrgoodwrench
Minnesota
I have a dana 60 front diff with thorson locker and a 14bolt ff rear axle with detroit locker that im going to be changing gear oil in on my large heavy suburban. I have free 75-140 and 80-90. they currently both have 80w90 in them should i stick with the regular 80w90 regular or put in the run 75w140syn? I drive long distances and 4x4 with it any input welcome. Thaks mike
Not familiar with the thorson. If it uses clutch plates, I would avoid the synthetic there. That messes with the friction modifiers
I’d sure run it in the rear though
I would think that the synthetic would be fine with that. I have used semi-synthetic with a couple of them, one is behind a D-max, and they work well.
Not a huge deal one way or the other, but would probably go with the 75w-140 if I had the option for free.
