I see no point in using synthetics in old vehicles that have lots of miles driven on regular lubes...the main advantage to using synthetics is to prevent wear better right from the start..once a wear pattern is established after many miles of regular lubes,the synthetics may provide a slim degree of further protection,but by then,the "damage" is done already..
While the more expensive synthetics wont likely do any harm to old parts ,it might too- (some may disagree,and I too have seen some engines fail shortly after a switch to synthetic oils that had regular oil in them up until that point,might just be coincidence---
-or maybe not ?)..
In my old trucks that have had conventional lubes used since new,and everything needs topping off regularly,I just stick with regular motor and gear oils--that is what they had when they were new,it was good enough then,it still is now..if I had a new vehicle I'd probably use synthetic after the break in period with regular lubes,unless they specify synthetics from day one..
