Gear pattern check
bigred88
Divide, Colorado
Any input on this pattern? It's for an AMC 20, but I figure gears are gears and you guys have been my go to for any diffs I've set up in the past. The drive side looks spot on to me, but the coast side is sitting a little toward the toe. BL is .010, I know I need to take that in a touch but I ran another pattern at .004 and I couldn't see much of a difference (didn't take pictures though).
I think my pinion might be sitting to deep, and that I need to take a few thousandths out of those shims?
Thanks for the help!
I'd like to see the teeth closer into the root, on drive side. the coast side does look like it running off the end. not very familiar AMC third member, just the axle hubs.
I am thinking you need to add a few thousands to pinion. And move that ring gear into the pinion, take away on right add to left shim packs.
