Gear Question
Hossbaby50
3/4 ton status
Peoria, AZ
Ok, will a set of gears for a rear 10 bolt from an 89 work in a front from an 85? I am pretty sure the answer is yes, but want to double check. I know they had changed to the 30 spline carrier in 89, and want to make sure they didn't change the gears in any way. Thanks
My Chevy isn't broken, its just out of gas.
Can someone help me out here? I got a line on a set of gears, but need to know this info first. Thanks
Harley
My Chevy isn't broken, its just out of gas. <a target="_blank" href=http://coloradok5.com/gallery/albuo73>My K5</a>
only change i know of is the 28-30 spline in 89. i have an old 10 bolt 28 spline in the rear and a 89 30 spline in the front, and when i ordered my new gears about a year ago they were the same according to randy's ring and pinion. and i just ordered new yukon axles for the rear and stayed with the 28 cause my lockrite is a 28 spline.
anybody else?
It needs a bigger motor.
what's in it now?
doen't matter it NEEDS A BIGGER MOTOR
89 350tbi/700r4h/np208/4.11's
