Gear question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ray Reynolds, May 15, 2019.
  1. Ray Reynolds
    Ray Reynolds Registered Member Premium Member
    Nov 28, 2017
    85
    14
    Build(s):
    what gears where typical in the Jimmy's and stock K5's with 350/700r4. My rear doesn't have the tags and was curious. I'm gonna pull the diff cover eventually but not anytime soon
  2. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    608
    116
    Terre Haute IN
    Build(s):
    My 90 has 3.73s, but it also came with an engine oil cooler and a hitch, might be a tow package of some kind, though I've never pulled the RPOs.
  3. Ray Reynolds
    Nov 28, 2017
    85
    14
    Build(s):
    Well here's my issue. I think, and it's kinda messing with me, that they've been changed. I'm running 35's and that should make the Speedo off by about 10-15 mph. So if it's reading 65 I'm going damn near 80, but it's actually doing the opposite. At 65 on the Speedo I feel like I'm only going 55. Going to have a buddy go 55 tonight as I follow him just to get a definite read
  4. diesel4me
    Jul 24, 2003
    23,882
    5,383
    Massachussetts
    Larger tires make the speedometer read slower...smaller tires make it read faster..more revolutions per mile = higher readings..
    This tire comparison chart shows the difference in the amount of revolutions between two different tire sizes ..type in both tire sizes and you'll see..
    Tire Size Comparison
  5. Ray Reynolds
    Nov 28, 2017
    85
    14
    Build(s):
    Ya I get that so why is it doing the opposite. I'm guessing someone has either changed the gear that drives the Speedo or changed the axle ratios
  6. bigblock454
    Jun 18, 2002
    608
    116
    Terre Haute IN
    Build(s):
    If you have an Android phone you can use GPS Status to show your current speed, it's free. Not sure if available on iPhone or not.
  7. Ray Reynolds
    Nov 28, 2017
    85
    14
    Build(s):
    Dammit... I have iPhone.. Lol
  8. sweetk30
    sweetk30 selective wrench turner guy Premium Member
    Nov 1, 2004
    31,706
    6,710
    horseheads , ny 14845
    Build(s):
    4
  9. nvrenuf
    nvrenuf Next weekend... Premium Member
    Jan 7, 2002
    16,126
    2,951
    Mobile, Al.
    Build(s):
    You didn't state the year of the truck but I'm guessing it's the one in your build thread (1987). The gear ratio depends on the current standard equipment for that model year plus the options ordered on that truck. That said, my bet is 3.07 which is by far the most common.
    Topp_rolmc likes this.
  10. 5akman
    5akman Registered Member Premium Member
    Aug 12, 2018
    49
    50
    Chico CA
    My 1988 has 3.73's .
  11. nvrenuf
    Jan 7, 2002
    16,126
    2,951
    Mobile, Al.
    Build(s):
    3.73's are extremely rare in a 1/2 ton, not saying you're wrong just that they aren't common. My '91 had 3.42's.
  12. diesel4me
    Jul 24, 2003
    23,882
    5,383
    Massachussetts
    The '85 K10 Suburban I have has 3:73's factory...I think the trucks with 700R4's had other ratios besides the 3:08's more often than those with three speed automatics..
  13. 5akman
    Aug 12, 2018
    49
    50
    Chico CA
    it was tagged as 3.73 and when I pulled the gear set to change out the pinion bearings, the ring/pinion were 3.73. Maybe a special order?
  14. dyeager535
    28,677
    786
    Best I can tell with the trailering option you could/would get 3.73s. There are three listed ratios for the '87 K5 in the dealer brochure (3.08, 3.42 and 3.73).
    In any case, 3.73's were spec'd with a 12,000 combined vehicle weight rating (truck and trailer) in a K5. No idea how they got three different combined weight ratings in the K5, but they did.
    Can't recall if the K5's could be spec'd with different brakes, I want to say yes, only because I've seen different brake RPO's listed on parts websites, not necessarily because that is the truth lol. Perhaps it was along the lines of trailering package or not, then trailering package with or without better brakes.
  15. AZK5
    AZK5 1/2 ton status Premium Member
    Feb 22, 2000
    470
    9
    Chandler, AZ
    Jack up one of the rear tires, transfercase in neutral and count the driveshaft revolutions to spin the tire once. 3 times 3:08, about 3 1/2 times 3.42, and almost 4 is 3.73. If you live on a hill make sure you block a tire that is still on the ground.
    skunked likes this.
  16. Ray Reynolds
    Nov 28, 2017
    85
    14
    Build(s):
    ya I thought about this. I'm gonna do it tonight. Thanks man
  17. diesel4me
    Jul 24, 2003
    23,882
    5,383
    Massachussetts
    If the diff lube is old,and could stand to be changed,you could pull the cover off and read the ratio stamped in the ring gear,it'll have two numbers like 41:11(which = 4:11 ratio) ,you divide the larger number by the smaller one to get the ratio..that is the best way to be 100% sure what ratio it is...the spin the tires method can be confusing and not accurate because of the spider gears..
  18. Justin V
    Justin V I should've stayed up there Premium Member GMOTM Winner
    Apr 17, 2016
    4,765
    6,429
    Colorado
    Build(s):
    41÷11=3.727272
    Which is 3.73's.
    nvrenuf likes this.
  19. diesel4me
    Jul 24, 2003
    23,882
    5,383
    Massachussetts
    I never was much good at math without a calculator !.. :blush:..:doah:..
    I was going by memory--I looked in one of my Chilton's manuals and they stated 41-11 is 4:11 ratio too,so they printed the wrong info !..
