buffblazer
ok while back there was a post with what size tires, tranny and gears you run and it would tell you your rpm at a certain speed. well after reading the chart, it said i was running 4:10's in the rear, well i checked today and i had 41 ring gear teeth and 11 pinion, so thats 3:73 right? so if someone dont mind reposting the thread im talking about or just tell me im on crack then it will be all good. thanks
