Thanks for the link! That is the calculator I’ve been messing around with. I really like how all the ratios are preloaded.
So if you have 37" you should be running 4.88 right?I always lean on the aggressive side. 5.13's
ran them with 40's and 44's.
my daily was 35's with 4.10's, 350/700R4, and always thought it needed more....
80% off road, I'd go 5.13's!So if you have 37" you should be running 4.88 right?
Since 5.13 was good for 44"
In case my post was not clear, the 4.88 were perfect with the th350 and I was wheeling moab with rarely touching the throttle except when front locker was not working.I have been playing with gear ratio calculators a ton but would love some real world feedback.
I am planning on going through the axles early next year and am starting to compile parts. Curious to hear what gears you guys are running in rigs that are primarily trail use. The K5 will be towed to the general area of the trails but will be driven to the trailhead. Last rig had 6.17’s and 41’s but not enough power to hit 5th gear. The Blazer has the extra 4 cylinders that one was missing.
Current Drivetrain: 350, 4L60 (700R4), NP241, D60/14BFF with 4.10’s, 37’s
Planning to stay 37’s on this one
What is your experience with any of these ratios? Any regrets?
If you go 5.13, you'll be wishing you have double overdrive
Depends on his expectations however I would be more than happy with 65mph @ 2100 rpms with the 5.13's.
I need to do the math on that one but my th350 was at 3000 rpms at 65mph so I was not happy with that. The overdrive fixed that.Depends on his expectations however I would be more than happy with 65mph @ 2100 rpms with the 5.13's.
