B bigjohnson1985 Newbie Joined May 26, 2009 Posts 4 Reaction score 0 Location utah May 26, 2009 #1 what gears will fit in a front dana 44 thatcame stock with 3.73 want to go as low as possible like 4.88
76zimmer Flyin Rat Staff member Moderator GMOTM Winner Joined Nov 14, 2005 Posts 33,011 Reaction score 34,792 Location Kzoo, Mi May 26, 2009 #2 http://www.precisiongear.com/dana44.htm
mr.smartass 1 ton status Premium Joined Aug 10, 2004 Posts 10,866 Reaction score 19 Location Hattiesburg, MS May 26, 2009 #3 Tech Note:When replacing a 3.73 and numerically lower ratio gear set with a 3.92 or higher gear, the case must be changed to a 3.92 and higher case. Click to expand...
joecowap Registered Member Joined Mar 19, 2006 Posts 58 Reaction score 0 Location Moscow Mills, MO May 26, 2009 #4 Don't they have the thick gears for a dana 44? Yes I believe the gears that have two part numbers are. The ones ending with + are the thick gears that will work on a numerically smaller carrier like your 3.73's are
chevyuser74 1/2 ton status Joined Jun 19, 2006 Posts 1,472 Reaction score 0 Location Mukwonago, Wi May 26, 2009 #5 deeper the gears though weaker the teeth
