gears
shadowwolf28
Newbie
U.P MI
HI i am some what new to 4 wheeling i have a stock 87 blazer. with a 4 in lift what gear should i use i am thinking 33 or 35 .some tell me 410 or 456 . will some one help . will 35 fit under 4 in lift also what kind of back space should i use on them .what size rim 8 or 10
HELP
Well thats a loaded question. Welcome to the boards man!!!!!!! Alot of folks are running 35s with 3.73. then after that its pretty sparatic from 4.10 to 4.56. What is your intended 4x4 application, ie. mud, rocks, sand, daily driver, everyhting and then some? I am going to be running 3.73 with 35's. Now I would probably jump intothe middle of the ranges and say go for 4.10. It should give you enough room to grow in tire size. And will give you low end bump and mid range gas out of the three( 3.73-4.10-4.56)
8 or 6 lug axles?
I am going with D60/14FF - 4.10, 4" lift, 35s on 16x10 wheels with 4 1/4 backspacing
I have the 700R4/4L60 and NP241
Dave
Beauty is in the eye of the beer holder.
If your wheelin go with the 4.56 since you rpobably have a OD tranny. If it's a daily driver I would stay with the 4.10's
There's my 2 pennies. Dont spend them all in one place.
When in doubt.....Use the Saws-all
<A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
Here we go again. Just do a search on these topics and you will see all posts you can stand. Some from the past few days. I am not typing all that again.
Jim '80 GMC
Freedom First!
<A target="_blank" HREF=http://www.bigjbear.coloradok5.com>http://www.bigjbear.coloradok5.com</A>
Lighten up on the new guys. They are just trying to make conversation.. If you don't want to retype it. Find it and copy and paste it.........Dan
