supernaut
Registered Member
I've got an optima red top battery in my '75. It sat and got discharged, but I've since had it hooked up to a battery minder. At the moment it reads 10.7 volts without any load on it and drops to 3.4volts when I turn it over. I've heard these things are bulletproof. With a normal lead acid battery I'd assume it just lost its capacity to hold a charge. Perhaps the battery minder isn't doing work properly?
