gen 1 doubler question
leadfoot067
puyallup, washington
has anyone else installed a gen 1 doubler in a blazer with a 14 bolt with a 465? if so what did you do about the rear driveshaft? i have serious driveline angle problems,ive dropped the t-case 1" and it helped but i think im gonna have a serious vibe problem,although havent driven it yet.my rear drivesheft is 29.5 inches long and has a 19degree angle on the shaft. so any suggestions would be appreciated.
shane
CV joint is the answer in this case. It's still a lot of angle but tipping the pinion up will help and the CV should handle the angle. It's not great but I think it'll work.
