Has anyone found an AC bracket for these swaps that don't require changing all or most of the drive setup? I'm looking at a power steering bracket that might fit where the old vacuum pump was (I still have to check if there is enough clearance).
If anyone has been down this road what did you go with and why? I'm looking for a simple and clean setup. Also at this point the build is getting pricey, so a lower cost option would be great if it exists. Thanks.
