Hello everyone,
I would like to thank everyone in advance for help that is given to me with the build of my k5 blazer. This is my first off road vehicle build and havent quite figured it all out yet
To start off I have a few question about the best route to take with my blazer. Here is were I am at in the build. I have a 1982 k5 blazer which use to be a 6.2 diesel and is now a carburated 358 it has stock baby axles and a 6 inch lift and 37 tsl super swampers it has the 700r4 tranny and 208 transfer case which I just blew up on my last trip with it. This blazer will only be for use off road no daily road driving. I just finished up the complete over haul of a 14 bolt ff rear for it and I am jumping into a complete over haul chevy dana 60 front for now. I have it pretty much broken down besides getting the bottom kingpin cover off, which are soaking in pb as of right now. I plan of doing a arb air locker in it or some type of power locker with 5.13 gears as well. I just picked up a set of pretty much new 44" boggers for it. I also have a turbo 400 and a 2 speed power glide that can be used for it but havent decided which to use yet. Also I am about to finish up a breaker box and cutting out all the old electrical from the diesel and whatever else that is not needed.I live in florida were there isnt any real rock crawling or much trail riding it is all pretty much deep mudding, but would like to do some trail riding if the oppertunity arises.
So here is were the questions start with it. I have tried to reserch this without any real definit answer I would like to go with the highest lift possible before having any major pinion angle probems and having super dollars on 2 piece drive shafts. I am planning on having leafs made for it and I am willing to do about a two inch body lift and cut the fenders a little but the less the better even with the body lift.I would like to get about 10" or more if possible and I havent gotten a transfer case yet until i know what will work best with the lift and everything. I am leaning toward a married 205 since the blazer has such a short wheel base but am not sure if the divorced would be better or if a np 200 would be better. I would prefer to leave the leaf spring hanger were they are but will move them if I need to and I will already be cutting the leaf purches from the axles to make them fit so if If they can be moved foward a little to help with pinion angle I will also do that.
If I could get some opinions on what would be the best path to take to save some money and to be the most reliable. I am sure many of you have had experience with your builds. Thanks again for any help.
