Today I changed the engine oil/filter, the transmission filter/pan gasket/fluid, and replaced the power steering return line because it was leaking.
Now that I got all those leaks to stop (for now) I noticed the steering gear box itself is leaking from the location in the red circle
Is this something I can fix myself? If so, how involved/hard is it to do?
I also need to reseal the rear axle (GM 12 bolt). I have the lube locker differential cover gasket and a Yukon pinion seal. I plan to remove the axle from the truck to clean and repaint it. Are there more seals I should look at/replace? Is it easier to replace the pinion seal while the axle is sill on the truck, or does it not matter?
I plan on pulling the leaf springs and cleaning/painting them as well. How difficult is that to do? I've read that I should replace the U bolts when I do this, do you all have any recommendations, or are they all pretty similar? I should probably replace all the bushings too, should I go with polyurethane or will stock rubber do fine for my relatively stock truck?
Thanks in advance for any help.
