Gettin' Old
alcan makes them to your specs too. big questionaire thing online to give full detail of what you have and what you want. I'm VERY happy with mine. just under 1000 for a full set.
Adjust the steering stops in a little to avoid rub at full turn left and right. Saves axle u-jopints too...
you know i had 32-11.50 on mine and never had a issue,and would think 33 should be ok,just a educated guess,i am now back to 31-10.50 ,just seem to work better with a stock 1990 blazer
I'll check into these. Sounds like an early Christmas present, maybe the ONLY one.
Seems like alot of people have no prob and some do. I think it depends on the actual measurement of the tires. My 32s Really measure 31. Ive seen alot of 33s brand new actually measure 32. I know my buddies trxus mts that measure 33 barely fit and i couldnt turn AT ALL.
My 37's, are actually 35"..., :doah:
you wouldnt be disappointed. ORD will design a set and have alcan build them too if you want to go that route. I got mine directly from alcan and got all my u bolts, brake lines, shocks and pitman arm from ORD. just under $1500 for everything. that was before I knew ORD would design springs though.
as an example. I have a 2011 toyota rav4, 88 crewcab on 6" unknown lift, my kids 72 blazer (stock), my gf's 84 z28, and a 99 jimmy. My 88 burb with 33's and 3" lift is the best riding thing I have.:waytogo: the rav's close but not quite better
