Ok, It's been a while since I poked my head in here, but I figure y'all would be my best bet for this.
I have a 94 12 Valve 5 spd one ton Dodge with 156,000 miles, it's been sitting for about 6 years, with the occasional start to move it around the yard, most recently being a year and half ago, and that time, it didnt want to start, and when it did, it would not idle for about 15 minutes I had to keep it from dying, and had white/grey smoke for the first 12-20 minutes as well.
I put a big, deep cycle marine battery in it, and it cranks over plenty fast, but it does not fire, I cracked the injector lines loose, and when cranking there is fuel bubbling out, But I feel there isnt enough pressure, So I think either the overflow valve is bad, or, more likely, the fuel is no good.
Also, I took the intake horn off and squirted some fresh diesel down into it, and it did pop.
How do I go about getting the old fuel out? I cant get a hose into the tank, there is some kind of screen or mesh about halfway down the filler neck.
