XHitman396
DIAGNOSED (see last post)
My original thread can be found here: http://coloradok5.com/forums/showthread.php?t=264094&highlight=thermostat
After messing around with the thing a bit more, I changed the thermostat again and I still have the exact same problem. I tried getting the air out of the system, but really had no idea what I was doing. Piecing together some tips, I propped the front of the truck on jackstands and fired the truck up, I ran the truck with the radiator cap off at a little higher rpm than idle, and around 210 the thermostat seemed open as coolant came blasting out of my radiator.
The truck continued heating, unphased, until I let off the gas. I refilled the radiator and tried it again. Then I did it a couple more times with the radiator cap on. Nothing helped.
The truck just basically overheats when loaded. It will redline no problem unless I let off the gas completely for about 10 seconds, then the temp drops quickly to below 200. I load the engine to accelerate back up, and it overheats again.
By now I realized I don't know what I'm doing. So what's the deal here? It was suggested that I just drain the whole system and refill it, hoping the issue is resolved, but besides that, all I can think of is to replace the already new water pump.
Thanks for the help.
