I’ve been chasing a gremlin that I can’t get rid of. At highway speeds - my temperature goes hot (On flat ground over a few miles at 65 mph -TBI temp at right rear of block - above 230) but cools right off at speeds below 50. I’m turning around 3000 rpm at 65 mph on days above 90 or 95 (In Phoenix)
I fairly confident that the tbi sensor is accurate. It’s back on the water jacket now and reads very close to a inferred thermometer.
Already done:
Complete flush of the system
New hoses
4 core aluminum radiator
Flex a lite electric fans (4,000 CFM) - puller
AC condenser sits in front of the radiator
Small power steering cooler for PSC also sits in front
Nothing blocking the radiator
I have a bearing noise at the front of the engine and I can’t tell if it’s the alternator or water pump
No leaks
No coolant loss
No indication of coolant in the oil
The water pump is maybe 6-8 years old, but not many miles.
stock 350 with a TBI conversion. No engine codes.
The fan had flaps that look like they’re there to let air through at higher speeds.
I feel like I’m throwing parts at the problem and don’t want to go down that insane road.
What am I missing? What should I be looking at? Is it possible for a water pump to be going bad without seepage? Should I look at the Edelbrock high performance water pump?
Already done:
New hoses
No leaks
No coolant loss
