Gfci outlet trouble
TJ1978
I have MANY questions
East Valley, Arizona
garage gfci 20amp tripped today using my ruining pressure washer to clean the c10 frame, I could not get it to reset.
So went to Home Depot and got a new 20amp gfci... went it fine, light shows green like it is working, however. When anything is plugged into the outlet I get nothing from either input.
Thoughts?
Sounds like you lost the neutral possibly.
Still doesn’t work... I turned the braker off and on even though it wasn’t tripped. The outlet just doesn’t work now.
I can’t even get the gfci to trip it just has the green light on and no way to get it off and nothing works when plugged in
Pull the GFCI receptacle, with an AC voltmeter, test for voltage between the black wire and green wire then test the black wire to white wire. Both should be 120v. Once verified 120v, hook the wires to the Line terminals (not the load terminals)...black wire to gold skrew and white wire to the silver skrew and green wire to the green ground skrew.
Restore power and reset GFCI receptacle, then test for voltage. GFCI receptacles need power initially to reset them, they come in the tripped setting when new. Once reset, it will stay reset even if power is cut off after the fact.
