glove box codes
78Suburban
Georgia
everyone on here says to look in the glovebox at the code panel.. am I missing something? my glove box just has like some kinda plastic liner and that's it.. I wanted to see if the gov-80 bomb code was on mine, but don't see the panel? where is it supposed to be in the glove box?
Its normally a white sticker on the plastic inside the glove box. You'll be lucky if its readable, or even there in your 78
Not always..
The RPO codes listing isn't always in the glove box(69-72 GM trucks had them inside the glove box door)--most 73-87 GM trucks have the code sheet laminated in plastic,and they glue them to the drivers side inner fender...not many survive there more than 5 years or so... I've found some "build sheets" under the seat,tucked between the springs and the padding on a few trucks..that might still be there if the seat's original,and the other "list" is gone...
One day long ago I was under my van,changing the oil--I noticed a factory hole in the unibody rail,it had a peice of paper in it!--at first I thought it was MONEY!! :laugh: --but after I spent 15 minites digging peices of it out,I was able to read it--it wasn't money :doah: :frown1: --it was the RPO code sheet--evidently someone stuffed it inside the boxed frame rail!! :mad: :crazy:
Mine is an 87 and it is inside the glovebox on the door just in front of the little pocket on the drivers side of the glovebox. Since it is inside the glovebox it is protected and is style quite legible.
Ira
They obviously changed the sticker location in the mid-80's. My '83 was on the fender, every year after that I've seen has had them in the glovebox.
diesel4me said:
most 73-87 GM trucks have the code sheet laminated in plastic,and they glue them to the drivers side inner fender...not many survive there more than 5 years or so... :crazy:
To find this RPO sheet in the fender would I open the hood?
Yup.
Yes--under the hood,on the inner drivers side fender..IF its still there!..as Dorian said,they started putting them in the glove box during the 80's..as were the 72 and older ones!..Why didn't they just KEEP putting them there?? :rolleyes: :crazy:
My 78 has the RPO code sheet in the glove box. The emmisions decal is under the hood. Never heard of RPO code sheets under the hood before.
on my 89 burb scotsdale 6.2 it is in the glovebox. the "rpo" codes are the 3 letter/# things right? where do you decode that at anyway?
Great question. I'm not sure of any source. However on the RPO build sheet it has the codes then the description to the right of the code.
It would be great to have a collection of all codes by year. This would be all the codes for all options along with descriptions. Maybe people could add there codes and the forum could build a collection.
uhhm they were all on glovebox in all the trucks thative owned 67-87 all cept a few 82 83 trucks, and ive owned and looked at a TON of trucks in the last eleven years,
all my 73-80 trucks RPO lables have been on glovebox lid
ALL of them
never under hood
janesville and st louis plants
on trucks 87 up the sticker only has the codes and no descriptions and the sticker size decreased by alot,
i dunno about otherr plants like in GA and cali and such, who knows where they put the label in thosae plants as ive never had a truck from any plants other than st louis and janesville
it must depend on year and plant
i bet you it does.,
if you dont have one on glovebox lid or under hood on wheel tub then its gone someone peeled it off, they are easy to peel off, from 73 to 87 anyways
67-72 and 87 up are impossible to peel, will ruin them they are real thin and glued on, just like in the cars(84 is the first car spid label and most all of them are glued to underside of the trunk deck on rwd cars, and to the spare wheel cardboard trunk floor cover panel on FWD cars) car oens list no RPO descriptions either and are smaller like the car ones,
the vans were stuck to uidnerside of hood most always on driver side and were same as the 73-86 truck ones with descriptions and all, though 86 probably like the trucks im sure
plant locations??
About 90% of all the trucks I see in my area and that I've owned were all made in Canada! :eek1: --they all have a maple leaf sticker on the door frame!..either that or the Tarrytown NY plant..I've seen very few trucks from other assembly plants--only one from TX,and another from MI..must be they ship trucks to the closest area to the plant..only makes sense not to ship them 1000+ miles!..they probably DO have different places to put the RPO sheet at different plants.. :confused: :crazy:
