I've got another question that I haven't been able to answer with searching (sites or Google).
Some time back I have read that there was a change to the glow plug post-heat control after the first few years. As I recall, it was basically a change to how the glows were utilized on warm starts, and the key difference was the water jacket sending unit. Along that line I've got 2 x 4005 senders and one 1047 sender. I assume the latter is from the demil motor, the other 2 from the civi donor motors.
But my question is, what do I want to run in the Sad Sub? Since the demil long block I built from was a 90 model based on internal engine stampings, and the 1047 is the oddball, I assume that's the one I want to use, presumably that will provide the desired later post-heat behavior. Is this correct?
